Paid 158 euro on blackfriday... quite a bargain, as its current 256 euro in my country
- no import tax or duty fees...
11 inch / 2 k screen / IPS
Snapdragon 662 octacore 2ghz / 4gb ram / 64gb storage (model tb-606f )
Android 11 out of the box ( with updates till 2024 )
Wifi 11Ac / BT 5.1
Batt 7500mah with adapter and cable
Camera 8 and 13 MP
Audio 4 speakers with Dolby atmos
Micro Sdcard slot (max 1Tb with exfat )
The interfaces...
Connected to Logitech k480.. it has a windows like interface
normally tablet interface
swipe right to left..its Google tv interface ( mediacenter)
The good :
Big screen size..large icons / multi window mode / split screen
good for reading magazines
Sound quality is really good
The screen is really good / dark and antiblue mode
No bloatware
supporters multi users
It got a few firmware updates
apt-x headphone.. Hd audio enabled : Apt-X Hd
Meizu hifi pro / dragonfly dac is working great ( for wired headphones )
Displaylink device is working..Connected to Tv
Lenovo forum offers a way to get root ( if needed )
the bad :
The tablet big and a bit clumsy to handle
possibly Ads
Not seen and community offering custom roms for the device
Netflix issue
Things i miss...
Hide apps from launcher
password protected apps
manage what app auto run at boot
Reported issues on Lenovo forum:
Dropdown boxes not working on sites ( not seen yet )
Lenovo tips - ads in the notifications tab ( not seen any ads..yet )
- However found the app : com.tblenovo.lenovotips ( Assistant )
-there no easy way to disable it ^ on Lenovo forum is way using adb
- using command : pm disable --user 0 com.tblenovo.lenovotips ( i did this )
-its part of apparaatservice and calls home to : push- row.zui.com / 47.254.178.141
- app named com.Lenovo.isf.device downloaded a new version to WNPushFiles folder
--best to block "phone home" by using Netguard
-- and change the permissions to read only on the WNPushFiles folder
Users on Lenovo forum complain...about no option to disable Work mode
- but under settings/work mode..you can disable it
- you can also use pull down menu notifications.. and disable Work mode
Netflix is asking for a update..to work, but Googleplay says not compatible wih device
url : https://forum.xda-developers.com/t/t...isted.4390027/
So, the preinstalled Netflix was is a modded one..and Netflix is blocking updates ( i think )
I did the code ####5993# is says Country code NOT SET
only way to uninstall it..is using adb or possiblyfix to side load a update?
- im lucky..that i have nvidia shield for Netflix
work in progress...
