UGOOS UT8 Pro Android 11 TV BOX RK3568 Quad-core A55 8GB RAM 64GB WIFI6 Gigabit RJ45 SAMBA HDR:
    CPU: Rockchip RK3568(Rockchip)+2.0G (64bit) Quad-Core Cortex-A55
    GPU: ARM Mali-G52 2EE
    Android 11.0 OS
    RAM: DDR4 4GB/8GB
    ROM: 32GB/64GB eMMC
    Support: 4K@60fps, HDR10
    Support: 1000M LAN, 2T2R Wifi 6, BT5.0
    Support: Audio Out, AUX-IN
    Support: 2*USB3.0 Host, 1*USB3.0 OTG, 1*USB 2.0
    Support firmware wireless upgrade function
    Configuration BT Voice Remote Control with Gyroscope
    There are two Options for UT8 series:
    UT8: 4GB+32GB+Wifi 6+1000M
    UT8 PRO: 8GB+64GB+Wifi 6+1000M
    That is a power house.............WoW!!!
    • mo123
      mo123 commented
      Editing a comment
      I think RK3588 still to come, will be the real power house
    well,I trust Ugoos and their Boxes
    But the quiz is "Rockchip"!!
    such as "all" 3566 Boxes sooo good
    so what about 3568??
    note;except SBC devies!
    as I'm talking about RC+BOX devices
    seems that almost everything is cool on paper!
    so,w'll see it what Ugoos did it or not!
      Hi ,
      think the Box is not bad , but still Quadcore , when will we see the first
      RK3588 Boxes , like Mo123 ask and why only 2Mali Cores , why not using
      one with more Cores , always the same with it ,
      greetings / gefattern
        Some good reviews on YouTube. This box looks very good.
          PPPoE in Ethernet present? (login & pass)
          Yundoo Y8 A6 [RK3399]
            • CPU: Rockchip RK3568(Rockchip)+2.0G (64bit) Quad-Core Cortex-A55
            • GPU: ARM Mali-G52 2EE
            • Android 11.0 OS
            • RAM: DDR4 4GB/8GB
            • ROM: 32GB/64GB eMMC
            • Support: 4K@60fps, HDR10
            • Support: 1000M LAN, 2T2R Wifi 6, BT5.0
            • Support: Audio Out, AUX-IN
            • Support: 2*USB3.0 Host, 1*USB3.0 OTG, 1*USB 2.0
            • Support firmware wireless upgrade function
            • Configuration BT Voice Remote Control with Gyroscope
            Geekbuying
            Geekbuying
            Specification as found
            General Operation System: Android 11
            Language: Chinese,English...Multi-Language support
            CPU: RK3568(Rockchip) CPU + 2.0G (64bit)
            GPU: ARM Mali-G52 2EE GPU
            SDRAM: 8GB
            Flash: 64GB
            WIFI&BT: 2.4G/5G 802.11a/b/g/n/ac/ax 2T2R wifi6
            WIFI Module(wifi 6.0) (AP6275P)
            ETHERNET: 1000MBPS
            Remote Control: BT remote with Voice+Gyro
            CEC: support
            RTC: support
            Power Supply: DC 5V/3A DC ADAPTER
            HDR: support
            Interface:
            HDMI Output: HDMI2.1 4Kx2K@60 max resolution output
            OTG: USB
            USB Port: 2*USB 3.0 HOST & 1*USB 3.0 OTG & 1*USB 2.0
            Data Output: 1*SPDIF
            TF Card: 1*TF Card
            Led work light: support
            Antenna: 2 Extra Antennas
            Network: 1*RJ45 1000M (Gigabit network)
            Audio out: 1 x AV Out &3.5mm
            Media Parameter:
            Audio Container: MP3,AAC,WMA,RM,FLAC etc.
            Audio Out: Supports MP3, AAC, WMA, RM, FLAC, Ogg and programmable 7.1/5.1
            Built-in SPDIF/IEC958 output and PCM input/output
            Built-in stereo audio DAC
            Video CODEC H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps
            H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps
            VP9 Profile0/2 [email protected] up to 4096x2304@60fps
            VP8 verision2,up to 1920x1088@60fps
            VC1 Simple Profile@low, medium, high levels, Main Profile@low, medium, high levels, Advanced Profile@level0~3,up to 1920x1088@60fps
            MPEG-4 Simple Profile@L0~6,Advanced Simple Profile@L0~5,up to 1920x1088@60fps
            MPEG-2 Main Profile, low, medium and high levels, up to 1920x1088@60fps
            MPEG-1 Main Profile, low, medium and high levels, up to 1920x1088@60fps
            H.263 Profile0,levels 10-70,up to 720x576@60fps
            Software Extension: Support Google Play & APK install
            DLNA,Miracast Protocol: Support DLNA,Miracast Protocol
            IM Software: Support Skype/QQ/MSN/GTALK (Depends on APK )
            Office Software: WORD/EXCEL/PDF(Depends on APK install)
            Others Parameters
            Operation Temperature: 0~60°C
            Storage Temperature -10~60°C
            Humidity environment: 5%-90%(No condensation)
            Certification: CCC,CE,FCC,Wi-Fi
            G
            eekbuying
              UGOOS UT8 Pro Android 11 TV BOX RK3568 Save $10 6TGK4IJO:
              Coupon time from Geekbuying
              Save $10 from Geekbuying
              6TGK4IJO
              Geekbuying
              6TGK4IJO
              Geekbuying
                is there works for a RK3588 device from UGOOS?
                Thinking of buying a box in the next year and wondering if I should wait or not
                  Most likely UGOOS will release a box with the RK3588, I don't expect them to have such a device ready for delivery till at least the beginning of next year.
                    Are there Linux distributions that work on Ugoos UT8 and UT8 PRo? Since the SoC RK3568 is also used in Mini PCs it should be possible...
                      minipc rk3568 where ?
                      just as the rest of the boards and boxes nope
                      if you get lucky they release a bsp linux-image with a old debian or ubuntu version
                      or some dts copied on a old armbian image
                      just buy a sbc board instead of a tvbox
                        This Mini PC for example : https://www.cnx-software.com/2022/04...ckchip-rk3568/
                        or this SBC : https://fr.aliexpress.com/item/1005002965401590.html
                        Armbian it supports Rockchip Chip usually
                          yeah that is just both a firefly board with their modified rockchip bsp linux with downstream kernel
                          yeah but no tvboxes and armbian is just as manjaro depending how or when the drivers land in mainline-linux so downstream dts files wont work on their newer releases
                            Sorry any twrp image for this model in the future with the new update of the twrp
                            TWRP 3.7.0 is out now for most currently supported devices.
