I have a CSA93 (Green PCB) that was working fine with DavietPDA's ATV 9 ROM until I messed up one of the system directories. This caused a bootloop rendering the box useless. So I then tried to reflash the ROM with USB burning tool where itt detected fine. However, when starting the flash process, it would always stop at 11% reading "enum error". So I decided to use the " "Force Erase All" option in USB Burning Tool in which it caused an error and the device went unrecognizable and disconnected from the computer. So I then tried doing the NAND Pin short method as before to recover the box possibly due to a broken boot loader. I've tried the suggested pins 6-7, 7-8 on the NAND and other pins for this PCB but there's still no life. Also connected a USB stick and a phone to the USB port to see if there is power but it does not. Only the blue light is working. Please help me find a way to recover this beloved box as I am out of ideas. All help is appreciated and thanks in advance!
Bricked CSA93 with seemingly no signs of recovery
I have a CSA93 (Green PCB) that was working fine with DavietPDA's ATV 9 ROM until I messed up one of the system directories. This caused a bootloop rendering the box useless. So I then tried to reflash the ROM with USB burning tool where itt detected fine. However, when starting the flash process, it would always stop at 11% reading "enum error". So I decided to use the " "Force Erase All" option in USB Burning Tool in which it caused an error and the device went unrecognizable and disconnected from the computer. So I then tried doing the NAND Pin short method as before to recover the box possibly due to a broken boot loader. I've tried the suggested pins 6-7, 7-8 on the NAND and other pins for this PCB but there's still no life. Also connected a USB stick and a phone to the USB port to see if there is power but it does not. Only the blue light is working. Please help me find a way to recover this beloved box as I am out of ideas. All help is appreciated and thanks in advance!Last edited by TeleVault; 01-11-2022, 18:33. -
did you tried the SDWay , AML Boxes can restored over SD too , if your Bootloader is bricked , then most
it only works over SD , but i am not a Pro with AML , but sure you can find much Info for it ,
further good luck / gefattern
Hi ,
Hmmmmmmm
This is older China Box
You will probly need original/ Stock Firmware burned to SD Card
More than likely Android 6
Or maybe that was the image you Burned?
Also this box is similar to H96 Pro Plus S912
Maybe android 6 version from Pro Plus may work
CoreElec/LibreElec for Am;ogic S912 may boot
Happy Testing
Happy TestingOriginally posted by sagert View PostI don’t know exactly this box, but I found a firmware for it. I’m not sure of course that it’s for this box, but they write that it’s for it. So I don’t know whether you will have luck or not. by myself. I saw more than one result there. You can find your own firmware on google:
https://www.getdroidtips.com/stock-f...-csa93-tv-box/
https://www.dropbox.com/s/rqizunwldn...80409.rar?dl=0
Buna ziua, de mult caut un loc de munca inginer, dar nu era de gasit, acum nu mai este nevoie. Cum am găsit deja noi cazinouri online evaluate pe https://mightytips.ro/case-de-pariuri/ este întotdeauna stabil și profitabil. Cu adevărat poți câștiga bani frumoși la cazinourile online. Este important să știi ce strategie să alegi și ce bonusuri să folosești în joc.
Originally posted by sagert View PostYou need to make a backup before any actions in twrp. And if you make a mistake, you can return to the working firmware through this backup.
I actually did make a TWRP backup about a year ago when upgrading the rom. But the problem now is how am I going to access TWRP without even getting to the recovery menu since it seems like that has been wiped off too.
There are currently 3411 users online. 3 members and 3408 guests.
