need firmware for x96mini p282
    Hi
    i have my device stuck on red light
    i tried many firmwares using usb USB_Burning_Tool but has no luck, upgrade stop at 4% with any firmware
    so it seems i should use stock FW to bypass
    Ram: 2GB
    flash: 16GB
    version: 7.1.2
    FingerPrint: Amlogic/p282/p282:7.1.2/NHG47L/20180822:user/test-keys
    notr: i could connect via usb using short Nand flash easy
    update:1
    it accepted bellow firmware in that page
    https://repairalltv.com/t95-s1-tv-bo...download-free/
    but this is not my stock , at less it worked but google play does not signing
    update2:
    i downloaded different FW from https://www.turewell.com/pages/tvbox-document
    FW: T95 S1
    it worked
    i flashed by usb + erase bootloader + write flash checked
      Hey, I purchased an x96mini a few days prior and execution is astonishing with Corelec, today purchased the "same" gadget for my sibling yet not booted. I introduce AIDA64 in the two gadgets and the old X96mini has a distinction, it says p281 inboard, while the new gadget say p282 inboard.
      returnsandrefund.com
        Originally posted by alaa2003 View Post
        update:1
        update2:
        FW: T95 S1
        it worked
        https://mega.nz/folder/Hs0RlRIR#-6_PPR-XZ09IksiwcW54ywduck life
        So the update was successful?
