Upgrade fail after Markrom Mode complete
Some observations
Maybe should listen to mo123
You are trying to Flash Android 9 with 1.8 ?
Driver Assist 4.4?
If you are in MaskRom Mode
Will have more success with Stock Firmware Andoid 6 / 7.12 to recover
Above your post is a Sticky by Silver
There is Firmware there and Different Utiliys Driver Assist,etc....
Happy Testing
HI ,
for sure you must use latest Drivers & Tools and use the right Rom as possible the Stockrom
for this Box , for sure a A7 Rom , or ??? , upgrade from A7 to A9 , or what was the way ???
Did you flash it without Power or what ??? more Infos always better to help ,
further good luck / gefattern
Ps : the tool not even show "download boot fail" or similar errors
There are currently 3666 users online. 0 members and 3666 guests.
