Slarm64 for X96 max plus 2 linux
Thanks for sharing,
I was looking for some linux for s905x3
On the Armbian forum, everything I found under s905x3 is removed.
I have launched "slarm64-current-aarch64-server-x96_max_plus-5.10.94-build-20220129"
there were no problems at startup
however, no command works
for example
#htop
#sudo apt install htop
apt-get, and so on, nothing can be run or installed
img.zst unpack : PeaZip : https://peazip.github.io/
There are currently 2784 users online. 2 members and 2782 guests.
