[ROM] ugslimtv Gt King Pro (Android 9)
    ugslimtv 042.7
    Based on Ugoos kernel
    Dev: SlimHouse
    Changes:
    • Added advanced Bluetooth settings
    • Added AOSP keyboard with Holo Blue theme by default
    • Added optimally configured Nova Launcher mod, activated as master (PIE)
    • Google services with less memory and CPU usage are used
    • Added support for Bromite SystemWebView (download from the project website)
    • Added image scale adjustment (dpi)
    • Replaced Setup Wizard (ATV)
    • Systematic amendments
    Clean installation is strongly recommended !!!
    Download ATV or PIE
    ugslimtv 042.6
    Changes:
    • Added to the free download settings
    • Fixing themes, using all the best optional colors
    • Added hours with no night time schedule
    • Added fuel index (TOX1)
    • Renovation of built -in applications
    • System corrections
    Download ATV or PIE
    https://slimboxtv.ru
      Hello, could you tell me if there will be a ugslimtv rom for the beelink gs king x? Thank you
        Directly contacting Slim House is the best method:
        Other method is to mod your own firmware (Mix and Match and UnBrick if necessary.)
        Telegram Chat (Russian)
        Telegram
        YouTube
        4Pda
        Another mod:
        GT-King WI-FI 6 (6B9X) WiFi 6
        Based on :ugoos v0.4.1 AOSP
        Dev: vadya7 (4Pda)
        (Not sure if this works on all PCB's)
          Please help me to enter the flashing mode of GT-King Pro, when using Amlogic USB Burning tool, after installed 0.4.2.7(ugsbx_beelink_gtking_p0_wol_atv_042_7.img) .
          I know: plug in usb cable from PC into OTG usb interface and power cord at the same time, then the Amlogic USB Burning tool will know the port.
          Now, I can not reflash firmware by using Amlogic USB Burning tool, or install Coreelec.
          My box: Beelink GT-King Pro, SB9H,
            What happened when you flashed the "0.4.2.7(ugsbx_beelink_gtking_p0_wol_atv_042_7 .img )"? Did the flash succeed??
              Yes, the flash succeed.
              1. I burned every release of CE 19, from 19.0 to 19.4 into SD Card by rufus.
              2. Copied dbt.img from devices_tree dir.
              Bootloader hang on “Upgrading…”.
              Why?
                Why?
                Fixed.
                Using the "SD Card Update" Method, We can succeed:
                1. Copy 3 files necessary for the "SD Card Update" Method, push the reset button of the box, until it comes into recovery mode.
                2. Connect the "otg" usb port with PC, whose "amlogic burning tools" is running and load the firmware and "OK" is clicked.
                3. choose "Reboot to bootloader".
                Then it runs well.
                Now, CE 19 can run.
                Thank all.
                  that was great thanks.
                    ugslimtv 042.8
                    Changes:
                    • TVLauncher disconnected from market updates (ATV)
                    • Added information to device settings - Source code version - encrypted or not
                    • Corrections for cursor and font selection
                    • Russian translation has been added to the settings
                    • Fixed program display (PIE)
                    • Added voice Ugoos default search
                    Download ATV or PIE
                      Good afternoon all. Does this have the auto refresh rate app pre installed?
                        ugslimtv 053.1
                        Dev: SlimHouse
                        Changes:
                        • added all project settings from version 042.9
                        • built-in Alpha Backup to backup your applications
                        • system corrections
                        Download ATV or AOSP​
                          slimBOXtv 42.1 and 54.1 (Android 9, based on factory firmware 0.4.2 and 0.5.4 from Ugoos)
                          • Has advantages (?):
                          • faster loading and response,
                          • working video scaling,
                          • turning on the set-top box with any IR remote control (item in the settings).
                          • remembering the state of the power when it is turned off.
                          Changes:
                          • Fixed pairing of Bluetooth devices
                          • Changed interface settings
                          • Fixed work Miracast
                          • Updated and activated ViPER4AndroidFX
                          • Added presets for ViPER4AndroidFX convolver
                          • Added selection of bootvideo, color settings icons, logo
                          • Increased the number of notification icons in the status bar to 10
                          • Disabled from updates in the market Atv Remote Service and Google splash screen
                          • Updated built-in applications
                            Version 54.1
                            • Miracast work fixed
                            • Built-in apps updated
                            • System amendments
                            Version 54.2​
                            • Added new bootvideo, logo, bootanimation
                            • System amendments
                            slimBOXtv 54.3 (Android 9)
                            • Fixed issues with Chinese font
                            • Added to app autostart settings
                            • Minimum Firmware Set (Copyright)
                            (Root by Magisk or SuperSu)
                            Issues I encountered -AOSP
                            1. No 4K display option.
                            2. Auto-hide toolbars failed after selection of display for Temp. or Sound ?
                            3. Recent apps window: return from Home Screen - Tiles would shrink to 1/4 size and app would open up partial view {wrong resolution??}
                            4. Youtube: recent Tile will center video ( 3x size of PIP) with massive black bars filling around the four sides {wrong resolution??}
                            ** Do not > Enable Freeform Windows < in Developer Options **
                            After reboot -this causes the Recent Tiles and re-opened apps to display shrunken proportions!​
                            Fix for # 3-4
                            (Expected to have text in Cyrillic>select English(US) and must reboot to clear left-over Crylic notifications. )
                            https://slimboxtv.ru​​​​
                              slimBOXtv 54.4 (Android 9)
                              Changes:
                              • Added UPlayer
                              • Vontar x3 dim power indicator during operation and during sleep
                              • Amendments to the display of processor temperature on the display
                              • Added New logo and bootanimation in the style of Google TV
                              (Maybe issues fixed from 54.3?)
                              Download ATV or AOSP​​
