[ROM] ugslimtv Gt King (Android 9)
    ugslimtv 042.7
    Based on Ugoos kernel
    Dev: SlimHouse
    Changes:
    • Added advanced Bluetooth settings
    • Added AOSP keyboard with Holo Blue theme by default
    • Added optimally configured Nova Launcher mod, activated as master (PIE)
    • Google services with less memory and CPU usage are used
    • Added support for Bromite SystemWebView (download from the project website)
    • Added image scale adjustment (dpi)
    • Replaced Setup Wizard (ATV)
    • Systematic amendments
    Clean installation is strongly recommended !!!
    For revision P0_WOL with SN number starting with C92X, SA9X, SA9X, 6B9X
    For revisionand P0_LP with SN number starting with 922X
    Download ATV or PIE
    slimboxtv.ru
    ugslimtv 042.6
    Changes:
    • Added to the free download settings
    • Fixing themes, using all the best optional colors
    • Added hours with no night time schedule
    • Added fuel index (TOX1)
    • Renovation of built -in applications
    • System corrections
    Download ATV or PIE
      ugslimtv 042.7 rom no link
        Check SlimHouse's website. Direct links to the firmware are frowned upon by developer.
          ugslimtv 053.1
          Dev: SlimHouse
          Changes:
          • added all project settings from version 042.9
          • built-in Alpha Backup to backup your applications
          • system corrections
          For revision and P0_LP with SN number starting with 922X
          Download ATV or AOSP
          https://slimboxtv.ru​
            slimBOXtv 42.1 and 54.1 (Android 9, based on factory firmware 0.4.2 and 0.5.4 from Ugoos)
            • Has advantages (?):
            • faster loading and response,
            • working video scaling,
            • turning on the set-top box with any IR remote control (item in the settings).
            • remembering the state of the power when it is turned off.
            Changes:
            • Fixed pairing of Bluetooth devices
            • Changed interface settings
            • Fixed work Miracast
            • Updated and activated ViPER4AndroidFX
            • Added presets for ViPER4AndroidFX convolver
            • Added selection of bootvideo, color settings icons, logo
            • Increased the number of notification icons in the status bar to 10
            • Disabled from updates in the market Atv Remote Service and Google splash screen
            • Updated built-in applications
            Download ATV or AOSP​​
            (Not all serial versions appear to supported)
              Version 54.1
              • Miracast work fixed
              • Built-in apps updated
              • System amendments
              Version 54.2​
              • Added new bootvideo, logo, bootanimation
              • System amendments
              slimBOXtv 54.3 (Android 9)
              • Fixed issues with Chinese font
              • Added to app autostart settings
              • Minimum Firmware Set (Copyright)
              (Root possible by Magisk or SuperSu??)
              https://slimboxtv.ru​​​
                slimBOXtv 54.4 (Android 9)
                Changes:
                • Added UPlayer
                • Vontar x3 dim power indicator during operation and during sleep
                • Amendments to the display of processor temperature on the display
                • Added New logo and bootanimation in the style of Google TV
                  slimBOXtv 54.5 (Android 9)
                  Dev:Slim House
                  Changes:
                  • Replaced ViPER4Android with a better version
                  • ViPER4Android built-in startup in settings
                  (Root by Magisk or SuperSu)
                  (Re-download -File amended)
                    slimBOXtv 42.6, 54.6 (Android 9)
                    Dev:Slim House
                    Changes:
                    • Added Acceleration button (clear memory) in TVLauncher (ATV)
                    • Keyboard LeanKeyKeyboardPro is used as the main
                    • Device certification in Play Protect
                    • Added a large wallpaper pack for your launchers
                    • System amendments
                      slimBOXtv 42.7 54.7 (Android 9)
                      Changes:
                      • Fixed setting wallpaper for TVLauncher (ATV)
                      • Colored default settings icons
                      • System amendments
                        slimBOXtv 42.8 54.8 (Android 9)
                        Changes:
                        • Added option to install updates from settings
                        • Added Dolby ATMOS
                        • Fixed ViPER4AndroidFX
                        • Added the ability to set a custom background for TVLauncher (ATV)
                        • Fixed disabling wallpaper in the settings for TVLauncher (ATV)
                          slimBOXtv 42.8.2 and 54.8.2 (Android 9) via update patch
                          Changes:
                          • Added to settings Download patch with updates
                          • Added to settings Ad blocking using hosts
                          • Added to settings Use Google DNS servers
                          • Added to settings Improve network speed
                          • Added to the settings Force wifi
                          • Amendments to the update installation mechanism
                          For revisionP0with SN number starting withB92X
                          For revision P0_LP with SN number starting with 922X
                          Download patch with updates for 42.8
                          Download patch with updates for 54.8
                            slimBOXtv 42.8.3 54.8.3 (Android 9) via update patch
                            Dev:Slim House
                            Changes:
                            • Amendments to setting the color theme of the interface
                            • Activation without rebooting colored settings icons and background for TVLauncher​
                              slimBOXtv 42.8.4 54.8.4 (Android 9) via patch
                              Changes:
                              • Returned the installation of their backgrounds for TVLauncher without rebooting, copy your picture to the UpdateSBXtv folder on the internal memory (ATV)
