No signal from hdmi on Tv box
Good morning hope everyone is in good health and is doing well... I am having a problem with this android box and i seem to can't understand what the hell is going on.. I have this nexbox a95x i know its a old box but it still works perfectly fine for what i want to use it for... I had removed it from the tv i had it on to update a kodi build everything was working fine no problem at all.. Now i put it back to the tv i had it on first now the tv can't see the box anymore, i only disconnected the HDMI port from the box only when removed it.. But when i connect back to the other tv it came from it works well i tried different cables the thing is all work with the tv i used when i was updating the build but none would work with the other tv i even tried to connect it to my brother tv and it doesn't see it either but when i connect it to the tv used when i update it worksTags: None
If you switched from a 1080p TV to a 4k TV, then you may not get any picture. You need to test it again on a different TV. That is happed to me before. Connect it back to the TV it works on, and check the resolution setting. Change the resolution setting to match the new TVs resolution.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostIf you switched from a 1080p TV to a 4k TV, then you may not get any picture. You need to test it again on a different TV. That is happed to me before. Connect it back to the TV it works on, and check the resolution setting. Change the resolution setting to match the new TVs resolution.
There are currently 2769 users online. 0 members and 2769 guests.
