How to root Vontar A95X F4?
    I need a root device to custom my project...
    I bought this device based on its hardware, however I need a rooted device.
    Does anyone already have a method to root Amlogic S905x4 and TWRP?
    I searched everything on google and youtube, but I couldn't find anything about it.
    My whatsapp +55 21 982351964.
    ​I speak from Brazil. My other old BOX is a T95Q. this device is so good. he have s905x2 with root at stock.
    if you can grab a image to burn in burning tool, you can patch the stock image and flash again, rooted. look at aidan youtube channel, there is a tutorial how to made this.
      Hello friend! I also have the same device and I also need the rooting procedures.
      The Youtube channel is "Aidan Macgregor"?
      I only found this youtube channel but it was not possible to perform the rooting because the Customization Tool program was not able to extract the file "recovery.PARTITION", to proceed with the Root. :-(
      Thanks for listening!
        you need a unix based system to extract and pack these images properly.
