DRM WIDEVINE L1
Originally posted by D7MY24 View PostI have Beelink GTKING and i installed update on it manually and because of that i lost DRM WIDEVINE L1. The question is can i get it back to Widevine L1?
thanks to Beelink for the good work , if there is no patch , i think you
must go back to the FW before , did you contact Beelink ??? , this is
a big Problem with this Boxes , after update L1 is gone , you are not the
only one , further good luck / gefattern
Originally posted by D7MY24 View PostI contacted Beelink 2 days ago but there's no response yet. Can you please explain what you mean by FW?
the Firmware / Rom that was on the Box before flashing , the working L1 one , do you have the Build Nr of your
before installed Rom ??? Screenshots , you can find it in Settings "about Device" so maybe others if they have
can share it , try to contact them over Facebook Twiiter , i think better then EMail , maybe you can find something
on 4PDA ,
but it is russian , but remember wrong Rom can brick or make Wifi useless because of other Drivers & Chip ,
think they not all have the same Wifichip , but not sure , further good luck / gefattern
There are currently 1549 users online. 2 members and 1547 guests.
