A95X F4 owners, help needed
    All
    I need some help from people who have the A95X F4 Box, please.
    Android 10 and 11, versions.
    Can you plug in a USB external hard drive, formatted NTFS and see if it detects and you can see its contents using file explorer.
    Please reply to me which Android version you are running and firmware and if it works.
    Thanks all
    I will try and tell you
      Andro 10/11
      NTFS/ExFAT supported
      I'v two ext.HDD and one of is NTFS and the other one is ExFAT formated! no any issue at all
      Therefore I'v USB-stick(3.0) formated ExFAT too(I use this HDD for my all pictures)
      My Box under "Stock" firmware and Andro-10 version
      device did it all OTA firmwares as well
      Note;for my experience that exFAT more stable and fast!
