A95X F4, TRUE HD Audio
    Hi
    The A95X F4, works with Dolby, but it doesn't work for TRUE HD Audio all the channels
    In the settings, I see that the firmware did not enable True HD audio in the selectable formats for pass-through but still works
    I've tried different versions of Kodi thinking that if it has its own codec it won't rely on android settings but get the same.
    When I play a file with True HD audio, it is played in dolby but downscaled, the input signal should show 8 but does and only shows 6 but the active speakers shows 8
    I wanted to ask if I use MX Player with added codecs, will this allow TRUE HD audio to be streamed regardless of whether it shows up in Android settings.
    I plugged in an old Android 7 box and everything works great regarding audio.
    I will really appreciate everyone's help here
    Thanks a lot
