Need help with my brick(kinda) S912 2/16
Hey! So, basically i messed everything up after installing the wrong firmware on it. My device is ddr3 and i installed a rom for ddr792 devices. So, after it got to %100 on aml burn tool, device didn't boot up and i realised what i had done. So, tried to install the correct fw but the pc did not recognise my device. I did the pin shorting method which was succesful but i can't pass the %7 "Uboot/Get result/DiskInitial error". I tried installing tons of roms from the aml burn tool but its still the same, gets stuck at %7. So, i tried the burn card method with a stock rom(i believe) but the green loading bar gets stuck at the start. (I format the card with rufus and burn the u-boot.bin with aml burn card maker. Then i copy all the rom files to the card and try to boot.) Any advice would be great, thanks.You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosTags: None
There are currently 1283 users online. 0 members and 1283 guests.
