H96Pro+ black screen and blue light
    Hey..
    I have a H96Pro+ 3GB/32GB V6.1 that went black when i flashed it with sd-card.
    Its new and came with Android 7.1.2 that had some errors, it couldent update from Google Play Store and it could not install apps via usb so i flashed it with sd-card. It showed the update logo and then the tv whent black, it can not get the red light on when i connect it to usb tool but it connect fine but the light stay blue.
    When i hit start in usb tool it starts to flash and stop after 2% ddr error.
    Do somebody know if this version is the same as version 6? So i can reset the chip by connecting pin 29 and 30 or is it not the same pins with this model.
    Thanks in advance.
    Se pictures for more info about the box
    You may only view thumbnails in this gallery. This gallery has 6 photos.
    hi, you can solve problem from this video https://www.youtube.com/watch?v=Hgw4S6RgRBE you may flash this ROM for your H96 Pro+ aml_7.1_s912_q9377-H96PROPLUS_mac-20170422.img (you can find from internet basicly).
      Thank you.
      I have try this and it dident work, i wil try again.
      The ROM you recomend is not for the LPDDR3 version, i have the ROM on my H96Pro+ with DDR4 ram and i have several ROM for the LPDDR3 model but usb tool give 2 different errors.
      I will take some pictures of the errors.
      What version of USB tool and which License files do i have to use?
      I have try several versions of USB tool and different License files.
      This is the pins i used but it did not work
      Click image for larger version  Name:	chip.jpg Views:	0 Size:	62.1 KB ID:	829449
      This is the errors i get in USB Burning Tool. The Last Error is a bit strange anynody that have seen this error before? I got the *Unknown* error 2 times then i closed usb tool and did it in another way and it worked on 2 boxes. it was not easy but now both boxes are working really nice.
        It is not possible to use this video to reset the H96 V2.2 V3.
        The reset can't be done like in this video because the board is not the same.
        This is how and where you can reset the H96 V2.2 V3.
        I have made 8 new costom IMG's for the H96 Q9733 912 3GB/32GB V2.2 V3 and V5, V6 + V6.1, and this reset picture.
        All of these 8 IMG works fine and will boot your bricked H96 V2.2 and my H96 V6.1 from SD-card and they are made 05-06 to 06-06-2022.
        The 6 IMG's can be downloaded soon and a video can be seen on Youtube i will provide the link ASAP.
        my H96 V2.2 V3 works perfekt and looks like this now.
        NEWER USE THE aml_7.1_s912_q9377-H96PROPLUS_mac-20170422.img ON YOUE H96 V2.2 V3 IT WILL F*CK IT 100% UP IT F*CKED MY H96 NOX UP.
        THIS IMG IS MADE FOR THE H96-Q9733 WITH DDR4 RAM BUT NOW I HAVE MADE THIS IMG FOR H96 Q9733 3GB/32GB WITH DDR3 RAM AND LPDDR3 RAM BOTH V2.2 V3 AND V5, V6 AND V6.1
          Look here if you need firmware for H96 Q9733 S912 3GB/32GB V2.2 V3 and for V5. V6 and V6.1.
          I made them and they are with bootfix, ramfix and more.
          So apparently there is a new firmware for H96 Pro+ LP signed as aml_s912_7.1_H96PROPLUS_mac_LP_20191115 listed on h96tvbox site. So far I have downloaded and flashed it last night - but that would be it. Please note I did not use USB Tool, nor Card method - I unpacked it in AMLogic Tools (ver.4), threw out garbage apps, added
