HK1x3 (round) S905x3 4/32 GB BT Gigabit
    Decided to create own thread since I dont know wether is same like rectangle one.
    Click image for larger version  Name:	HK1_X3.jpg Views:	29 Size:	46.6 KB ID:	829208
    Stock Firmware supposed to be these:
    32GB ROM version STOCK
    initial HK1_X3_S905X3_2019-11-23.zip HK1_X3_S905X3_1000M_U212_9.0.2019.11.23.18.29.img
    ALTERNATIVE TESTED ANYTHING working:
    u219_HK1_H96maxX3_Ath156Mod3_ENG_BarsEnable_190820 20.img
    https://drive.google.com/drive/folde...iEgZ5akGuKcc4u
    thanks ath156
    OR ATV 9 Aidans rom
    https://androidfilehost.com/?w=files&flid=333113 (recommended !!!!)
    THESE seem to bo for rectangle?
    SoC update 20201116
    https://mega.nz/file/II9wGY4I#p4Oo7k...IDeDcJiVZ0uZkI
    u219.HK1_BOX_1000M_9.0.2020.11.16.11.05.img.7z
    FIRMWARE: HK1 X3 with Amlogic S905W SoC (11-16-2020) (androidpctv.com)
    64/128 ROM version STOCK
    https://chinagadgetsreviews.com/down...-tv-box-2.html
    Build number: franklin-user 9 PPR1.180610.011 20210407 release-keys
    u219.HK1_BOX_1000M_9.0.2021.04.07.12.54.img
    Ram: 4GB DDR3 Hynix hstq4g83afr
    Wifi: hk 5230 zx190916
    Lan: rtl8211f
    Emmc: Samsung klmbg4gend b031
      If you feel "brave" try the ATV firmware I gave you. Most probably it will be OK. There is of course a chance that your wifi or some other component will not function. Of course there is always the possibility of getting a "brick", but as we know you can always revive the TVbox by shorting 2 pins. We know the 2 pins for the H96 max X3 (round TVbox) with Blue Board, but is seems to be different than yours. I think you are experienced in this and I may help you also (in case you get a brick). Anyway it is up to you.
      **Note: Have a look also here where it says that your HK1 is a clone of my H96 max X3, HK1 Box etc. Also see the ATV that he used which is for the clones of your TVbox. https://www.ixbt.com/live/tv/tv-boks...ic-s905x3.html
      **Note2: And here is a link of using my firmware at your TVbox !! But I think now it is better to use the ATV I gave you. Good Luck. https://tvboxstop.com/2020-tv-boxes/...akes-it-great/
        **Note2: https://tvboxstop.com/2020-tv-boxes/...akes-it-great/
        Thanks! Yes I know how to short in general but I know BGA boards little bit tricky :-( didnt know the guy was using your firmware ! Maybe Ill give a try stock is running good as well - didnt expect that
          Yes, but this was back to November 2020, when there were no better options/custom firmwares. At that time it was the best custom AOSP rom for this "family" of TVboxes.
          Since you are asking for an ATV rom, I think your best option now is to try the ugoos port I gave you a link here: https://forum.freaktab.com/node/8125...138#post829138
            What is difference between u212 and u219 board?
              These are just different versions of firmware and not of the board itself !!
                Originally posted by Kennyhack View Post
                The Vendor said its 100Mbit, but...
                On the chip it says:
                RTL 8211F
                1310CH1
                G1.11
                which should be a Gigabit chip ??
                When I make a Internet Speedtest I get more than 100Mbit upload speed.
                Click image for larger version Name:	LAN Chip.jpg Views:	0 Size:	130.9 KB ID:	829392
                I am still not sure which custom ROM I would have to install.
                My TV Box has AUDIO issues. When I play a movie, it crackles (HDMI) like the sync between Audio and Video is not working correctly. It does this in any APP that plays video (Youtube, Kodi, IPTV etc.)
                Click image for larger version  Name:	IMG_20220516_132832.jpg Views:	0 Size:	117.1 KB ID:	829397 Click image for larger version  Name:	IMG_20220516_132952.jpg Views:	0 Size:	137.5 KB ID:	829398 Click image for larger version  Name:	IMG_20220516_133035.jpg Views:	0 Size:	143.4 KB ID:	829399 Click image for larger version  Name:	IMG_20220516_133042.jpg Views:	0 Size:	152.5 KB ID:	829400
                which Custom ROM should I install????
                  [QUOTE=Kennyhack;n829396]
                  Observations From Images
                  No one can tell you which File/Custom Rom to Flash
                  That decision Rests on Your (KennyHack) shoulders.
                  There are 20 plus Files that can be tested on Your China Box
                  With varying results of Sucess
                  Also different OPerating Systems
                  Armbian
                  CoreElec
                  Are 2 examples
                  Also Probably a SlimBox Version that may Work
                  Look for Files/Roms that have the Same Hardware as yours
                  Ethernet RTL 8211f
                  Wifi 5230
                  What you have described above RE: Audio issues
                  Souns like Hardware issue not
                  Software/Firmware
                  Maybe try a new HDMI cable
                  Test Box on Different Display/TV Monitor
                  Try the AV Output on Box
                  See if Same results AS HDMI
                  Good Luck
                  Happy Testing
                    [QUOTE=freddy;n829423]
                    You own this box?
                      [QUOTE=soldiaz;n832101]
                      Originally posted by freddy View Post
                      You own this box?
                      No
                        Could be software issue. I experienced stutter BT audio on my x96 air when using SLIMBOX . Therefore I use the stock which is really good too and does not have these bluetooth audio issues
                          ath156
                          Confirm: u219_HK1_H96maxX3_Ath156Mod3_ENG_BarsEnable_190820 20.img
                          runs very smooth on the round unit! I tried Supercelerons x2/x3 generic but had no wifi
