hk1 rbox x4 WPA3
    hk1 rbox x4 WPA3
    Hello everyone,
    Just wondering if anyone has a tip, trick, fix for WPA3 connections issues with android10 and up with boxes.
    I have tried NUMEROUS routers to eliminate that problem.
    Issue is, it simply can't connect. Infamous "check password try again" error.
    I have tried to manually add ssid network, also forcing it to wpa2 as well... still nothing.
    As soon as I drop security on routers to wpa2 box connects perfectly fine.
    WPA3 works perfectly fine with any other device capable of wpa3
