Please help guys, MK908 GPU Issue!!!
    I bought a MK908 TV stick from aliexpress recently. I recevied it today. Unfortunately, there is a severe problem with antutu test. It reboots during the test If I select all the settings, so I've only selected gpu test. Its getting around 10fps with lot of fragmenting. I checked it with my tv USB connector and provided USB power adapter. Please see the attached pics. What should I do?, is this mk908 defective. I have already contacted the seller, no replies yet. Please reply guys!!!.
    Regards,
    SamClick image for larger version
ID:	438718Click image for larger version
ID:	438719Click image for larger version
ID:	438720Click image for larger version
ID:	438721Click image for larger version
ID:	438722Click image for larger version
ID:	438723Click image for larger version
    I would::
    Try a differnend benchmark..
    Mess with Settings/developer/ (anything related to gpu )
    Download a app like Cpu-info ( to see if anything is wrong h\w )
    Try a different hdmi cable / power source
    Try a few different monitors..
    See.. if there a 'stock firmware' availeble (perhaps reseller has a site /then reflash unit )
    If that fails.. contact reseller.. with issue (incl pictures or youtube vid as proof)
    Req : a solution , and ask for a stockfirmware.. in hopes to resolve the issue
    -note : be-friendly.. ask for a solution (keep msg clean.. translate friendly )
    Goodluck
      Problem Solved!!!
      I flashed its factory firmware to 720p MK908 Fineless ROM 1.6a. It solved many issues I had before like fragmenting.Got antutu score around 17K Many thanks to Finless Bob. Please keep up the wonderful work!.
        Thank you for the reply.
        Originally posted by mitchell4you View Post
        I would::
        Goodluck
        Finless Bob's firmware fixed the issue. Thank you for the advice.
