Possible to update x96 max vontar (Android 9.0) to Android 11?
    Hello guys haven't been on the forum for quite sometime. Life got in the way. I wanted to know is there any ROMs for this particular box. It's stated as being
    x96 max (vontar brand)
    Amlogic S905X3
    64bit quad core ARM cortex A55
    Android 9.0
    4gb 32gb rom.
    The reason I'm asking is because all my apps don't work with android 9.0 anymore which is really unfortunate for me. I use the box every day. Looking a possible Android 11 ROM. Or even 10 if available. Would love to keep the little box going.
    Apps like
    BBC iPlayer and others won't work on the device. Asks me to update via playstore but then it doesn't allow me to do because the device isn't supported anymore.
    Would love some input from some of you fine minds here. Thanks alot
    Anyone? If there aren't any compatible ROMs I would probs just order android 11 box but wouldn't like this little box to go into storage as it's a nifty wee number. Thanks
