I have been banging my head for the last few days trying to fix this T95Z Plus box. I do not think it's the Sunvell version, as there is no markings anywhere showing so. It is a 3+32GB version, I have taken the casing off to check the board (which is red), and says "MAL_t95zplus_168p_1103_v1.0" - I also see AP6255. I will upload a few photos shortly. I have tried over 20 different Firmwares, all fail at 2% with the code "Romcode/Initialize DDR/Read Initialize status/" error. I have tried different cables, different USB ports (a s905x box flashed earlier, same cable, same software just fine).I have to use the short pin method for the box to be detected, and start the actual flash, which fails at 2% every time, no matter what FW, ROM, cable, port etc.
I would like to know what kind of RAM this board has, what the stock firmware would be, and if there are any custom ROMS (aidans rom, atvxperience, etc) that I could use, without issue. If you could help, would be great (please try to send me links to the actual file that would be compatible) as I have tried literally, 20 different firmwares/roms, all to which fail flashing.
Thank you so much!
