TANIX TX3 Mini+ TV BOX Android 11 Amlogic S905W2 Quad Core ARM Cortex A53 4G RAM 64GB ROM 2.4G+5G WIFI 4K AV1
Upgraded Chipset Amlogic S905W2
Quad Core ARM Cortex-A35 CPU, ARM Mali-G31 MP2 GPU
Latest OS Android 11
With the newest UI and Multi-apps supported, have a better user experience for you!
New Generation Coding Format AV1
Higher picture quality and less bandwidth consumption, amazing!
https://i.imgur.com/yUBvdxx.jpg
https://i.imgur.com/h8CTGrU.jpg
https://i.imgur.com/4Gw6eGR.jpg
Specification
Model: TANIX TX3 MINI+ Type: TV Box GPU: Mali G31 MP2 System: Android 11.0 CPU: Amlogic S905 W2 Core: Quad Core ARM Cortex A53 RAM : 4G DDR3 ROM: 64G ROM |
Decoder Format: H.264, H.265, VP9/VP6/VP8 Audio format: MPEG-1, MPEG-2 (L1/L2/L3), MP3, AAC-LC, HE AAC V1/V2, APE, FLAC, OGG, AMR-NB, AMR-WB, G.711 (u/a) decoding • G.711(u/a), AMR-NB, AMR-WB, AAC-LC encoding • 3~5m far field sound acquisition, supports speech enhancement, acoustic echo cancellation and direction of speaker estimation. • Virtual surround sound Video format: Allwinner Video Engine (AVE) with dedicated hardware decoders and encoders Support multi-video decoder up to [email protected] [email protected] Supports multiple “secured” video decoding sessions and simultaneous decoding and encoding Video/Picture Decoding - H265/HEVC Main/Main10 [email protected] High-tier ;[email protected], up to [email protected] - H264/AVC BP/MP/[email protected], MVC, [email protected] - VP9, Profile 0/2, [email protected] 30fps - VP6/VP8, [email protected] - MPEG1/MPEG2 [email protected], [email protected], [email protected] - MPEG4 [email protected] 0~3, [email protected] 0~5, GMC, short header format, [email protected] - AVS /AVS JIZHUN [email protected] 6.0, [email protected] - VC-1 [email protected], [email protected], [email protected] 0~3, [email protected] - Supports Frame Buffer Compression(FBC) - Output pixel format configurable,YUV420/ YV12/NV12/... - Real-time image decoding- Maximum resolution up to 65536 x 65536 - Integrated JPEG hardware decoder - Configurable output pixel format- YUV420/YV12/NV12/... Photo Format: HD JPEG, BMP, GIF, PNG, TIF Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes WIFI: 802.11 b/g/n/ac Bluetooth: 4.0 Power Supply: Charge Adapter Interface: AV,DC 5V,Ethernet,HDTV Out, optical, TF card,USB2.0 Language: Multi-language HDMI Version: 2.1 Other Functions: DLNA, others HDMI Function: HDCP Power Consumption.: 10W RJ45 Port Speed: Support 10/100Mbps |
Power Type: External Power Adapter Mode Power Input Vol: 5V Power Adapter Input: 100-240V / 50-60Hz Power Adapter Output: 5V 2A |
Remote Controller Battery: 2 x AAA Battery ( not included ) |
Product weight: 0.1780 kg Package weight: 0.370 kg Product size (L x W x H): 8.84 x 8.84 x 1.86 cm Package size (L x W x H): 17.20 x 11.20 x 6.20 cm |
Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x IR Remote, 1 x English User Manual, 1 x Power Adapter |
$43.99 after coupon:6J5WVKFU
