The method is outlined here: https://i12bretro.github.io/tutorials/0451.html
Basically, it involves copying the "TWRP Recovery Amlogic S9xx.img" as "recovery.img" to the root of any MicroSD card or USB Drive and then Booting up the Box while keeping the Reset Button pressed.
The method claims TWRP is NOT installed. The device Only Boots into the TWRP Recovery. To make the TWRP Recovery Permanent, simply Flash the recovery.img file using the "Flash" Option and selecting Recovery partition.
If anyone can try this safe method, please report the findings.
A TWRP Recovery and its importance need not be repeated.
