This mini-PC is the newer version of the previous Beelink U59 Similar Case and style.
The newer Beelink U59 Pro is using Intel Celeron N5105 processor, 11th Generation Jasper Lake chip,
Manufactured at 10 nm with very low power consumption.
The newer Beelink U59 Pro has enough newer hardware to run Windows 11 without problems, excluding the problems that windows 11 has
Easy to use for a small home office computer, Web and Multimedia players up to 4K@60fps resolution.
The additional features included 2 HDMI Out plus Also Via USB C and the dual Ethernet port.
Let’s me get the screw drivers and camera and we will have a look see soon.
https://www.bee-link.com/catalog/product/index?id=334
The Beelink U59 Pro mini-PC with the Intel Celeron N5105 processor.
Quad Core chip at 10 nm can reach up to 2.9 GHz.
Using the Intel UHD Graphics GPU with 24 execution units that reaches 800 MHz
Tad beefier than other Celeron CPUs.
RAM there is two versions available 8/16 GB DDR4 with two slots for DDR 4RAM
Also includes a M.2 SATA SSD 500 GB capacity, and an SSD port for 2.5-inch.
Wireless dual-band Wifi AC and Bluetooth 4.0.
4 x USB 3.0 ports, 3.5 mm audio jack with microphone support,
Two Gigabit Ethernet ports and 2 HDMI 2.0a + USB-C video outputs that allow 4K@60fps video playback
In the box as always included with Beelink VESA compatible bracket to hang it, 2 x HDMI cables Power supply.
Unit is installed with Windows 11 Pro.
Not a power House Unit, build quality like most of the Beelink range is pretty Good and should be an easy run For Linux and a range of emulators etc.
More will be found Here:
https://forum.freaktab.com/node/830236 <- Click
