Here are there specs of their newest product using the Ryzen CPU.
【High efficiency processor】: S3 comes with AMD Ryzen 5 3550H ,max turbo frequency up to 3.7Ghz.This small pc can fullfilled your versatile senarios usage such as home entertainment, streaming video, web browsing , work and games delivers incredible responsiveness and smooth.
【Expandable Large Storage】: Configurable memory to 32GB of single card and 64GB of dual card, optional configuration of 16GB memory.
【Radeon Vega 8 Graphics&Dual Display】 : Support dual screen display, it is perfect for your office and entertainment.
【Cooler & Quieter】: Silence and run smoothly.With strong heat dissipation capacity and easy to carry when traveling around.Dual heat conduction tube.
【Reliable warranty service】:We will provide you with a one-year warranty, 7* 24-hour one-to-one customer service, and lifetime technical support. You don't need to worry about quality issues, TRIGKEY will serve you wholeheartedly.
Here is my review, using it as a PC, will be making another video demonstrating the capabilities of a Home Theater PC (HTPC).
