I came across this new box/mini PC and found one Youtube review on it. Has anyone got any first-hand knowledge of it? It looks like it just might be the Shield destroyer that the youtube reviewer claims. But there have been many boxes that people have made that claim about.
Youtube Review
CPU | Quad-core ARM Cortex-A76 MPCore processor and quad-core ARM Cortex-A55 MPCore processor, both are high-performance, low-power and cached application processor |
GPU | 3D Graphics Engine * ARM Mali-G610 MP4 * High performance OpenGLES 1.1, 2.0 and 3.2, OpenCL 2.2, Vulkan1.2 etc. * Embedded 4 shader cores with shared hierarchical tiler * Provide MMU and L2 Cache with 4x 256KB size * The latest Valhall architecture * ARM Frame Buffer Compression(AFBC) 1.3 * Support Serial Wire debug for embedded MCU * One isolated voltage domain to support DVFS |
NPU | * Neural network acceleration engine with processing performance up to 6 TOPS * Include triple NPU core, and support triple core co-work, dual core co-work, and work independently * Support integer 4, integer 8, integer 16, float 16, Bfloat 16 and tf32 operation * Embedded 384KBx3 internal buffer * Multi-task, multi-scenario in parallel * Support deep learning frameworks: TensorFlow, Caffe, Tflite, Pytorch, Onnx NN, Android NN, etc. * One isolated voltage domain to support DVFS |
Video-codec | * Real-time video decoder of MPEG-1, MPEG-2, MPEG-4, H.263, H.264, H.265, VC-1, VP9, VP8, MVC, AV1 * MMU Embedded * Multi-channel decoder in parallel for less resolution * H.264 AVC/MVC Main10 L6.0 : 8K@30fps (7680x4320) * VP9 Profile0/2 L6.1 : 8K@60fps (7680x4320) * H.265 HEVC/MVC Main10 L6.1 : 8K@60fps (7680x4320) * AVS2 Profile0/2 L10.2.6 : 8K@60fps (7680x4320) * AV1 Main Profile 8/10bit L5.3 : 4K@60fps (3840x2160) * MPEG-2 up to MP: 1080p@60fps (1920x1088) * MPEG-1 up to MP: 1080p@60fps (1920x1088) * VC-1 up to AP level 3: 1080p@60fps (1920x1088) * VP8 version2 : 1080p@60fps (1920x1088) |
JPEG-codec | JPEG Encoder * Baseline (DCT sequential) * Encoder size is from 96x96 to 8192x8192(67Mpixels) * Up to 90 million pixels per second * Embedded four encoder units JPEG Decoder * Decoder size is from 48x48 to 65536x65536 * Support YUV400/YUV411/YUV420/YUV422/YUV440/YUV444 * Support up to 1080P@280fps, and 560 million pixels per second * Support MJPEG * Embedded four encoder units |
Display | * Support multi-display * Support HDMI 2.1, DP(display port) video output, and also HDMI input |
Interfaces | HDMI2.1 and DP video output, HDMI input, dual G-LAN, Mipi, GPIO, RS232, RS485, PCIE, SATA 01, SATA 02, USB 3.0, USB2.0, debug, Type-C |
Operating system | Android and Linux Ubuntu |
