A95X Max S905x2 Android 9 ATV firmware.
A95x F2 and A95x Max(S905x2) use same rsa and aes key for signed bootloader,dtb,boot.
I modded A95x Max bootloader to boot A95x F2 firmware Android 9 stock or ATV9.
A95x F2 (Ampac) firmware(stock(Android9) or custom rom ATV9) can be flashed(USB Burning Tool) to A95x Max(S905x2) without modded anything but system see only 2Gb Ram, bluetooth and lan not work, but wifi,vfd and all firmware work very good.
A95x F2 (mediatek) firmware not work without modded bootloader.
But with modded bootloader work all work.
This firmware image (USB Burning Tool) is SlimBox version (sbx_a95x_f2_mediatek_atv_9_11) only changed bootloader.
Tested on A95X Max (S905x2) with:
Board ver. 2018-12-28 A95XMAXV_V81
WiFI (Mediatek MT7668RSN)
Lan RTL8211F
VFD HT1628
Working temp. 50-60C
Work all.Fixed problem with lan.
Slimbox 9.12 for A95 Max X2
26.12.2023
Download
Mod dtbo fix lan.
Github
