KKSB Khadas VIM4 Aluminum Case
    KKSB Khadas VIM4 Aluminium Case – Black
    Following along from their successful Vim 3 case we now have a case for the Vim 4:
    This KKSB metal case has been designed for effective passive cooling. It is made of CNC-machined aluminium. The case is compatible with the Khadas VIM4. The case has labelled cutouts for Khadas VIM4 interfaces and connectors.
    The case cover has been designed to work as a built-in heatsink. The fins on top of the case have been designed for better heatsink performance since these fins offer a larger contact area with the air. This design optimises passive cooling.
    On top of the case, there is an opening for the GPIO Header. The case comes with 4x rubber feet for stable and scratch-free desktop orientation. The base of the KKSB Khadas VIM4 Black Case has two pre-cut mounting holes for wall mounting.
    Khadas VIM4 microcontroller has three buttons. The KKSB Khadas VIM4 Black Case comes with push buttons for Function, Reset and Power.
    Quick and Easy Assembly
    You can set up the KKSB Khadas VIM4 case in minutes:
    • Remove the plastic on both sides of the thermal pad
    • Insert 3x control buttons to the relevant cutouts (inside-out)
    • Align the mounting holes of Khadas VIM4 board with the spacers on the base of the case
    • Secure the board to the bottom of the case using screws
    • Mount the cover of the case on top and secure with the help of screws
    • Fix the rubber feet
    Properties of KKSB Khadas VIM4 Aluminum Case
    • Material: Aluminium
    • Finishing: CNC-Machined / Black
    • Board Compatibility: Fits Khadas VIM4
    • Interface Support: Labeled cutouts for HDMI, CSI, DSI, VB1, USB Ports, MicroSD Slot, Ethernet Port, and GPIO Header
    • Passive Cooling: The cover works as a heatsink | Fins on top for optimal heat dissipation
    • Orientation: 4x rubber for desktop orientation | 2x pre-cut mounting holes for wall mounting
    • Control Buttons: Buttons for Reset, Function, and Power controls
    Articles Included
    • KKSB Khadas VIM4 Case (Black)
    • Rubber Feet
    • Fasteners
    https://kksb-cases.com/products/kksb-khadas-vim4-case-passive-cooled
    Also a work in Progress I am advised:
    For those that like it Chunky
    More soon:
    If you have a Vim4 you may need one of these:
    Thanks to KKSB, let's have a look see at what we have here
    The Box
    All the Bits to make it Happen
    Inside and base
    Side Buttons to Fit etc
    Out with the Old
    In with the new, fits like a clove
