Khadas Newest Big Boy on the block:
Rockchip RK3588S, 8 nanometer ARM SoC
Edge2 is powered by the RK3588S, a next generation 8-core 64-bit SoC from Rockchip.
The RK3588S is Rockchip' s newest flagship IoT SoC utilizing the 8 nanometer lithography process.
As a result, power consumption is similar to the RK3399, yet we have achieved an overall performance boost of up to 2.5 times.
Octa Core Processor
Edge2 is equipped with an 8-core 64-bit CPU (up to 2.25GHz clock speed).
x4 2.25GHz Cortex-A76 performance cores are paired with x4 1.8GHz Cortex-A55 efficiency cores.
Extreme GPU Performance
The RK3588S has an integrated 4-core GPU, the ARM Mali-G610 MP4 (up to 1GHz clock speed) which supports a lag-free 4K user interface.
3D rendering has been greatly improved and you can play expansive open-world online games, console games and even some AAA titles.
High Performance NPU
The RK3588S has a built-in NPU which provides up to 6 TOPS (tera operations per second) of neural network processing.
The NPU supports mainstream deep learning frameworks, such as TensorFlow, PyTorch, MXNet and so on.
The powerful RK3588S brings optimized neural network performance to various A.I. applications.
Quad Display Interfaces
x1 HDMI, x1 USB-C, x2 DSI
Edge2’s hardware supports up to four independent displays.
This greatly expands the potential applications of Edge2 in multi-display scenarios such as digital signage, development and gaming.
https://docs.khadas.com/software/oowow/start?redirect=1
https://www.khadas.com/shop?Collecti...rice_descending
