I have a problem with the A95X F3 Air II
Bought 2 days ago. After connecting the configuration and running, for example, Kodi started to go out with it and hang. The screen froze and you see with a crackling sound. 3 times it was from new since it was turned on to reset for the 4th time it didn't move anymore.
I wanted to lose him soft again, but it comes to 3%. I copied the end from the error file.
[16:11:46 343][Hub4-5][Err]--Wait connect timeout,burn failed!
[16:11:46 347][Hub4-5][Err]--Burn failed
[16:11:46 347][Hub4-5][Err]--open C:/Amlogic/Aml_Burn_Tool/V3/ErrorMsg_English.xml
[16:11:46 399][Hub4-5][Err]--romboot/boot bl2/USB/read
[16:11:46 399][Hub4-5][Err]--wait connect failed! romboot/boot bl2/USB/read
Send it back to the supplier or is there anything I can do?
THX
