HELP PLEASE!!!!
HELP PLEASE!!!!
This tv box can't install any apps. when i try the android system return the message "App wasn't installed" and nothing more. Then i tried to hard reset (button) but theres not a button in the AV direction (see the image please). What can I do for hard reset this tv box please?
Tags: None
Originally posted by askanison View Post...What can I do for hard reset this tv box please?
Hi @michaelfoggin , The yellow pins seem to be on the same Ground plane so I would try to short yellow with the pink circle, as per below. What device is it? Do you have the model number? - Synology External Storage
or from terminal execute command reboot recovery, and delete dalvik/cache (or do factory reset).
Originally posted by mAtvXk View PostShort soldering pads where the reset button was,
https://www.ifixit.com/Answers/View/...n#answer718204
edit: sadly short soldering pads didn't solve the trouble. where can i find some guide about terminal command? please!Last edited by askanison; 14 February 2023, 22:10.
There are currently 2431 users online. 0 members and 2431 guests.
