Google translate:
This is the QZ version, so it is intended for TV boxes of versions 4/32 GB and 4/64 GB (the firmware is not intended for TV boxes 2/16 GB).
Stock firmware with date 20200729 does not have statusbar-navigation bar.
The stock firmware with the date 20191126 is faulty (after a month or two, your Android will fall apart). That´s why I publish, for me, this best stock firmware for TV box QZ version.
Note: for the TV box Tanix TX3 S905X3 version 2/16 GB, the version marked BZ is used.
Firmware characteristics:
- Alice UX lite edition launcher,
- RGB 8 bit mode for old TV if it is pink screen,
- Root-noroot mode (HBO MAX and Apple music app run in noroot mode),
- Web videos in Chrome, Opera, Firefox browser applications do not work, so use the Dolphin browser from the google store, which supports Adobe flash player. This is due to the fact that for Android 9 Chinese TV boxes, Adobe has disabled the use of Adobe flash player.
- some wifi mouse do a double double-click, so change the wifi mouse to another type and the problem will disappear (I use a wifi mouse C-TECH WLM-08, 1200DPI).
Download img in zip file "Stock firmware Android 9 for Tanix TX3 S905X3 4/32,64 GB, 20191021" from google disk for Amlogic USB burning tool program here:
Good luck.
