Please help me rk3318
Originally posted by yxbox View Post
the Problem is that your Nand not has the typic Pins , so it could be difficult to find the right Pins ,
you could try to use two of the four contacts that can be seen on your nand side , but no guarantee
that it works , but for sure even this way soldered PCBs have Points to restore , but they are not well
known and from PCB to PCB different .
I think they are direct beside the Nand , somewhere where you can see the three holes with golden
edges around them . ( above the blue Led Light )
hope you get it , further
good luck / gefattern
Hint : for restore you need the Stockrom or a known working Rom
There are currently 2140 users online. 0 members and 2140 guests.
