With an Intel N100 chip manufactured in 10 nm, this little ripper delivers solid performance without chewing up too much juice. It's a top choice for desktop use, and with two HDMI 2.1 video outputs that support 4K@60fps and a Gigabit Ethernet port for speedy file transfers, you won't be left in the lurch.
The Beelink MINI S12 looks grouse on any desk, and you can even hang it from its VESA support behind your monitor if you're short on space. It comes with a 256 GB NVMe disk as standard, and while it's not lightning-fast, you can add a 2.5" SATA 3 disk to boost storage. Plus, there's a single SODIMM slot that lets you expand the RAM up to 16 GB.
This beaut comes with Windows 11 pre-installed, so you can hit the ground running and browse, stream, or work with ease. And the cooling system is tops, with a quiet internal fan that keeps performance humming along smoothly. Sure, you might hear a bit of fan noise during games, but it won't throw a spanner in the works.
All in all, the Beelink MINI S12 is a fair dinkum mini PC that's quiet, efficient, and perfect for browsing, streaming, or working on everyday tasks at home.
Box:
What's in the Box:
Front
2 x USB3, Power, CmosReset and Headpset Jack.
Rear:
2 x HDMI 2 X USB3 Ethernet and Power
Pop the base:
We have Room for an SSD, Fitted with 16gb Ram 500GB NVME
