Leotec Show 2 432
SoC: S905W2 RAM: 4 GB Internal storage: 32 GB WiFi and bluetooth chipset: AW3155-50R VFD: FD6551 Ref: LETVBOX19
The original firmware sucked so much that the keyboard didn't even allow me to insert the WiFi password. There was also no root.
So I installed the slimBOXtv firmware for the Vontar X2 (also S905W2 SoC), but as expected the WiFi and the VDF don't work.
The problem is that after flashing the firmware for the Vontar X2, the USB Burning Tool doesn't recognize the box anymore so I am unable to try other firmwares. I'm stuck with the slimBOXtv firmware.
If I get the stock firmware maybe I can flash the u-boot.bin with the Amlogic BootcardMaker and be able to use the USB Burning Tool again.
If you know where can I download the stock firmware please tell me. Thanks.
