HELP TANIX T8 MAX
    HELP TANIX T8 MAX
    HELP TANIX T8 MAX
    Good morning,
    I bought this box some time ago which still has Android 7. something.
    I would like to update it with something newer. But I haven't found anything specific for this box here on the forum, so I would like some help from you on which ROM I should flash.
    I don't know which WiFi chip my box has (there are two versions), but it has 3 GB / 32 Gb.
    Mainly I'm interested in games, not Netflix or prime. In particular I would like to try the Dolphin emulator so I definitely need a 64bit rom.
    Thank you for your help in advance.
    E.
    If it helps, I found this presentation on this forum:
    TX8 MAX TV Box S912 Android 7 3/32GB Dual WiFi Gig Lan BT4
    White clean looking unit, if you're into white that is.
    White remote easy to find and different look good to see.
    So lets have a look
    The Box
    What's in the Box
    Ports, TF card on side
    Facing Down side
    Click for Larger Image
    Facing Up side
    The Lid and good ventilation on either side of lid excellent.
    The Base
    Looking pretty good well made Samsung Chips, AP6255 WiFi,
    Good to see, as small as it is Thermal Pad between heatsink and Weight Block
    Myself will cover with a bigger piece if required,
    All Fired up running Android 6.0.1 at present, date 20170321 to old.
    Beta Android 7.1.2 it will be...
    More to come...
    [/QUOTE]​
      Right above your Post is
      Firmware/Roms/Tools
      Thread by ReaperMan
      Android Pie for S912
      The OP has a plethora of Roms to Test
      The main thing is to confirm Ram
      LPDDR
      DDR3
      DDR4
      SDRAM
      there are many many variations in these boxes
      Also make sure you research how to unbrick your Box before trying anything.
      Again above your post
      Knowledge & Tutorials
      Happy Testing
        Thank you very much for your response.
        Do you know an easy way to see what kind of RAM the box has? Or do I absolutely have to open it up look for the memory chip?
        Thanks again!
        E.
          There are apps for Android like
          CPUZ
          AIDA64
          RAM TRUTH
          HW INFO+
          They are not always accurate
          In Terminal there is dmesg
          Best is to take box apart
          If Box is same as images you posted
          Look at Ram
          Is SEC BCRC
          Type in Big G search
          SEC BCRC RAM
          Looks like you have DDR4
          Good luck
          Happy Testing
