Raplace libstagefright.so
I have finless 1.7 in my mk808b. I ve found a newer version of libstagefright.so and i want to replace the one in /system/lib/ with the newer one. It doesnt let me because of permissions. I tried to change permissions with root explorer but it needs a specific folder for that. Any help how to do the procedure?
Thanks -
Originally posted by Haris1977 View PostI have finless 1.7 in my mk808b. I ve found a newer version of libstagefright.so and i want to replace the one in /system/lib/ with the newer one. It doesnt let me because of permissions. I tried to change permissions with root explorer but it needs a specific folder for that. Any help how to do the procedure?
Enable show hidden files in settings and choose Root Explorer somewhere at the bottom of the left menus.
Enable RW for the file systems. After you replace libstagefright.so, change the RW permissions back to default.
Just install this rom - http://www.freaktab.com/showthread.p...0730)-_Sep2013 and you already have the latest libstagefrigt.so file. Just remember you cannot use an Android 4.1 libstafefright.so file in Android 4.2 and vise versa.
Originally posted by mo123 View PostGo to your system/lib folder and replace libstagefright.so with ES File Manager.
There are currently 2675 users online. 1 members and 2674 guests.
