H96 Max X4 superimage rebuilding
    Hello!
    I asked this in XDA Forum, but nobody can answer it. I try here too...
    I have some problems Click image for larger version
ID:	832966 And sorry for my english.
    I bought a H96 Max X4 Android TV box from Geekbuying. I have factory firmwares for it, so i start to modify the device. It has Android TV 11 version.
    The device has root shell on adb, but the device not rooted itself.
    The problems are:
    I can unpack superimage from stock firmware, and able to do dd backup super from device. But i can not use fastboot flashing because of "FAILED (remote: 0ffff13c)" error.
    The number changes depending on which superimage I am trying to write.
    This is not real problem, beacuse of i can use dd for flash back the images.
    But...
    If i try to write back the backuped superimage or what extracted from stock FW, everything is okay. But the unpacked and repacked image causes bootloop.
    The lpdump says the device's metadata and the repacked superimage's metadata are the same:
    ohm:/ # lpdump
    Slot 0:
    Metadata version: 10.2
    Metadata size: 1104 bytes
    Metadata max size: 65536 bytes
    Metadata slot count: 3
    Header flags: virtual_ab_device
    Partition table:
    Group: amlogic_dynamic_partitions_a
    Attributes: readonly
    Extents:
    0 .. 1839895 linear super 2048
    Group: amlogic_dynamic_partitions_b
    Extents:
    Extents:
    0 .. 357943 linear super 1843200
    Extents:
    Extents:
    0 .. 854999 linear super 2201600
    Extents:
    Extents:
    0 .. 1559 linear super 3057664
    Extents:
    Extents:
    0 .. 133159 linear super 3059712
    Extents:
    Super partition layout:
    super: 2048 .. 1841944: system_a (1839896 sectors)
    super: 1843200 .. 2201144: vendor_a (357944 sectors)
    super: 2201600 .. 3056600: product_a (855000 sectors)
    super: 3057664 .. 3059224: odm_a (1560 sectors)
    super: 3059712 .. 3192872: system_ext_a (133160 sectors)
    Block device table:
    Partition name: super
    First sector: 2048
    Flags: none
    Group table:
    Maximum size: 0 bytes
    Flags: none
    Maximum size: 1876951040 bytes
    Flags: none
    Flags: none
    I use this command to repack the superimage:
    ./lpmake --metadata-size 65536\
    --device-size=2415919104\
    --metadata-slots=3\
    --super-name=super\
    --group=amlogic_dynamic_partitions_a:1876951040\
    --group=amlogic_dynamic_partitions_b:1876951040\
    --partition=system_a:readonly:942026752:amlogic_dyna mic_partitions_a\
    --partition=system_b:readonly:0:amlogic_dynamic_part itions_b\
    --partition=vendor_a:readonly:183267328:amlogic_dyna mic_partitions_a\
    --partition=vendor_b:readonly:0:amlogic_dynamic_part itions_b\
    --partition=product_a:readonly:437760000:amlogic_dyn amic_partitions_a\
    --partition=product_b:readonly:0:amlogic_dynamic_par titions_b\
    --partition=odm_a:readonly:798720:amlogic_dynamic_pa rtitions_a\
    --partition=odm_b:readonly:0:amlogic_dynamic_partiti ons_b\
    --partition=system_ext_a:readonly:68177920:amlogic_d ynamic_partitions_a\
    --partition=system_ext_b:readonly:0:amlogic_dynamic_ partitions_b\
    --image=system_a=/super/system_a.img\
    --image=system_b=/super/system_b.img\
    --image=vendor_a=/super/vendor_a.img\
    --image=vendor_b=/super/vendor_b.img\
    --image=product_a=/super/product_a.img\
    --image=product_b=/super/product_b.img\
    --image=odm_a=/super/odm_a.img\
    --image=odm_b=/super/odm_b.img\
    --image=system_ext_a=/super/system_ext_a.img\
    --image=system_ext_b=/super/system_ext_b.img\
    --virtual-ab\
    --output /super/supernew.img
    The unpacked modified superimage and the unpacked stock superimage gives the same files.
    For more information here are the imjtool results:
    Original, factory superimage:
    ./imjtool /mnt/rawsuper.img
    MMapped: 0x7f9606303000, imgMeta 0x7f9606304000
    liblp dynamic partition (super.img) - Blocksize 0x1000, 3 slots
    LP MD Header @0x3000, version 10.2, with 10 logical partitions @0x0 on block device of 2304 GB, at partition super, first sector: 0x800
    Partitions @0x3100 in 3 groups:
    Group 0: default
    Group 1: amlogic_dynamic_partitions_a
    Name: system_a (read-only, Linux Ext2/3/4/? Filesystem Image, @0x100000 spanning 1 extents of 898 MB)
    Name: vendor_a (read-only, Linux Ext2/3/4/? Filesystem Image, @0x38400000 spanning 1 extents of 174 MB)
    Name: product_a (read-only, Linux Ext2/3/4/? Filesystem Image, @0x43300000 spanning 1 extents of 417 MB)
    Name: odm_a (read-only, Linux Ext2/3/4/? Filesystem Image, @0x5d500000 spanning 1 extents of 780 KB)
    Name: system_ext_a (read-only, Linux Ext2/3/4/? Filesystem Image, @0x5d600000 spanning 1 extents of 65 MB)
    Group 2: amlogic_dynamic_partitions_b
    Name: system_b (read-only, empty)
    Name: vendor_b (read-only, empty)
    Name: product_b (read-only, empty)
    Name: odm_b (read-only, empty)
    Name: system_ext_b (read-only, empty)
    And the repacked superimage:
    ./imjtool /mnt/supernew.img
    MMapped: 0x7f3a9dc5b000, imgMeta 0x7f3a9dc5c000
    Group 0: default
    Name: system_ext_b (read-only, empty)​
    Any idea for what is the problem? Waht does MMapped and imgMeta informations means?
    Thanks!​
