Slimbox Allwinner
    Slimbox Allwinner
    slimBOXtv 10.1 (Android 10)
    Dev:Slim House
    Changes:
    • Installed Magisk
    • Disabled signature verification
    • Disabled logging to dropbox
    • Added option to install updates from settings
    • HDMI CEC control disabled by default
    • Acceleration button (clear memory) in TVLauncher (ATV)
    • Keyboard LeanKeyKeyboardPro is used as the main
    • TVLauncher is disabled from updates in the market (ATV)
    • TVLauncher enabled the ability to activate a third-party launcher (ATV)
    • Support for init.d scripts
    Available for Allwinner H313 China Box.
    Прошивки, инструкции, приложения для Android TV Box
    (I do not have Allwinner...so I post this(once) to help forum members. )
    Telegram
    You can view and join @slim_box right away.
    Прошивки slimBOXtv для ТВ боксов и стиков Сайт проекта - https://slimboxtv.ru Реклама - https://t.me/mrSlimHouse Редактирование прошивок - https://t.me/mrSlimHouse
    YouTube
    A project to create firmware for TV boxes and sticks with an Amlogic processor. Amlogic S905X, S905X2, S905X3, S912, S922, S905W, S905W4, S905Y2, S905L (Android 9) Amlogic S905X4, S905W2, S905Y4 (Android 11) slimBOXtv ATV and AOSP are two...
    Thank you very much, working perfectly except system bars kn Atv versio. , please fix
      Beautiful
        Good work
          Please provide one for the H728 based X96Q Pro Plus. You'll be a lifesaver. Thanks!
            This is almost brand new box?
            With octocore processor
            Bells n whistles etc...
            Whats wrong with Firmware, came with?
            I don't think there is slimboxtv rom for this allwinner
            Will have to check website ​​
              The box turns off my TV after a while, unless I go into settings. turning off cec in the box does not help. only turning it off on TV helps. this does not happen with any other box.
                And you think slimboxtv ROM will fix that ????
                There us always a Master in CeC interface
                Your TV is Master
                Use TV settings for CeC
                Happy Testing
                  Your TV is Master
                  Happy Testing
                  Yeah, tested that already. It's definitely the box. Something is off about it. I am guessing only a firmware update will fix it. so far, no response from the manufacturer, but it's been the weekend.
