Which Android TV Box to buy these days?
    Hi all,
    I have tried the Imito MX2 and now the QX1. I got different issues with both... I am looking to find a replacement so I read and read and read on many TV Box on the Forum and for each one that I look at there always seem to be either reboot, WIFI, BT or other problems.
    My question is, does anyone has a stick that works flaw less? Good wifi, no crashes, good BT and so on... Quad core prefered.
    If so, with which model with which ROM?
    Thanks!
    The holy grail..lol
    I wish you luck..
      Originally posted by peety View Post
      I wish you luck..
      LOL
      It seems that no one has one of those!!!
        I recommend cs968
          Originally posted by convict View Post
          I recommend cs968
          Thanks! I will look into this one then!
            Not to hijack, I am much in the same boat, but additionally interested in 5GHz WiFi.
            What would be the right one?
              The CS968 works in 720p.
              Is there any devices that are working good in 1080?
                Originally posted by jy_p View Post
                Hi all,
                Thanks!
                If you're not a gamer, the MK808B is a really great efficiency for the price.and in bonus a tons of good firmware and troubleshooting.
                Bonjour! Je suis de Shawinigan, Québec, Canada
                  There is a 1080p rom from cloudnet. I tried it and it works
                    Tronsmart cx 919
                    Lewy HFW 1.2.1 rom for T428. Every thing works (Ive tried a bunch. Finless roms are good if you dont need camera support). Or Im currently running lewy's rom 2.0.4 for the K r42 (a few camera issues).
                    Your choice of kernel from here. Make sure you use a good power supply and cable if you run the overclocked kernels. The cable and psu that come with it are a bit cheap and nasty. Just flash these kernels with the tool provided in the finless packages (only kernel checked). If you run a 1080 kernel what i do is change the DPI in the build.prop to 240 using a root explorer app.
                    Its a pretty good stick and will play most videos I throw at it over windows shares etc. Xbmc runs well also, these are my main uses for it.
                    good luck
                      I finally ordered a cx919 too. So you are saying that the Lewy is the best Rom if i want use a camera?
                      Envoyé de mon Nexus 7 en utilisant Tapatalk
                        AW: Which Android TV Box to buy these days?
                        Originally posted by aidymp
                        xbmc aidymp style!
                        So you want to make money with the work of other people?
                        XBMC and the plugins are made by people, who invest a lot of time in their work. And they do it for free.
                        You grab your userdata folder and sell it for 2,50£.
                        Shame on you. That is not the idea of free Software.
                        I hope nobody will pay money for this.
                        Gesendet von meinem Sony Tablet S mit Tapatalk
