ATV10 RK3229/RK3228a. Two versions of WI-FI chip RK912 and RK915a
    1 ATV10 RK3228a - Chip WIFI Rk912
    HK1 LITE
    Quad Core RockchipRK3228A Cortex-A7
    1 ATV10 RK3229 - Chip WIFI Rk915a
    HONG TOP e X88mini
    - Google TV/ATV10 android
    - Gboard
    - Play Store working
    Note: Old TV box PCBA will either be incompatible or with LAG
    1) ATVRK3228A_HK1_LITE_RK912_10_root - Download:https://drive.google.com/file/d/12zbmOxETqE3SI-DCPZ9s0_9NlF4eZ0Bx/view?usp=sharing
    2) TECHLIFE_RK3229_ATV10_H20_X88_RK915a_root - Download:https://drive.google.com/file/d/1zid...ew?usp=sharing
    Click image for larger version  Name:	IMG20230817180212.jpg Views:	1 Size:	52.8 KB ID:	833257
    Click image for larger version  Name:	IMG20230817180359.jpg Views:	1 Size:	85.6 KB ID:	833258Click image for larger version  Name:	IMG20230817180414.jpg Views:	1 Size:	79.0 KB ID:	833259
    Click image for larger version  Name:	IMG20230817180459.jpg Views:	1 Size:	68.1 KB ID:	833260
    - Gboard
    Note: Old TV box cards will either be incompatible or with LAG
      Verry thank, I will test it
        check inbox to have issue sir
          is It 5g?
            Hello for everyone. I have a little situation.
            I install ATV 10 in my box. So far only the ATV 10 version has worked so nice. The big problem it's mistakenly recognizing 4 GB of storage when my TV boxes are actually 128 GB.
            Anyone have the same situation? Thanks
