Changes:
• Status bar with curtain and nav bar activated
• Added recent
• Added to settings Use Cloudflare DNS servers
• Added to the settings Connecting the Temp folder and transferring caching to it
• Fixes for Colored settings icons
• Added text scaling to settings
• Support for 8K, QHD, HD, SD has been added to the Screen Buffer Size settings
• Amendments to the Screen Buffer Size and Image Scale settings
Download ATV or AOSP
slimBOXtv 11.22.4 for X96 X10 (Android 11) via patch
Changes:
• Fixed navigation in settings using the mouse
Download the patch
slimBOXtv.ru
(I'm not sure if these apply to both pro and non pro.)
