AS FROM THE TITLE I ASK FOR YOUR SUPPORT IF ANYONE KNOWS STB ON HOW TO REHABILITATE IT........................THANKS
Originally posted by diablo67 View PostAS FROM THE TITLE I ASK FOR YOUR SUPPORT IF ANYONE KNOWS STB ON HOW TO REHABILITATE IT........................THANKS
that is good , but please edit your Thread & Title and change it to English , so everyone can understand ,
you only have to press "edit" and change it , then "save" it and all is good ,
what happend to your Box ??? do you have the stock Firmware ??? then you need PC to flash or SDCard
Restore your Box . If you not have the stock FW , what Wifichip & DDR is used is important too .
greetings / gefattern
Hi ,
Originally posted by diablo67 View PostI'll start by saying that I used USB Burning Toll to load the firmware but it doesn't communicate with the USB port. Then I changed the system via SD card using this firmware 1. [v9] Aidan's ROM [S905X] [ATV 9] (Universal RTL & BCM) but the flashing doesn't start the same
are you really sure it is S905X ??? , did you look under the Cooler , many of this cheap China Boxes had not inside what the User thought ,
Users thought it was Amlogic but the truth was , if they looked under the cooler , it was a Rockchip CPU ,
did the Firmware crashed , what happend that you are now in this state ??? did you saw in working state ,
with App like Aida64 that it really was a Amlogic CPU ??? , if you not know , if really Amlogic , look under it .
There are currently 2383 users online. 0 members and 2383 guests.
