H96 Pro+ (ZH01-S912-TVBOX-v2.0) Green
    i have this tv box { H96 Pro+ (ZH01-S912-TVBOX-v2.0) Green board} WISDOM variant
    the problem is some apps does not work anymore on it and i'm looking for any version higher than the stock 7.1.2
    the tv box works now on this firmware
    s912_q9377-H96_KDMC17.3_50ME_600M_mac-20170918.img
    I appreciate your help and thanks in advance.
    Hello,
    Try this Firmware, it should fix a Lot of Issues.
    Regards
    Neomode
