nfs support for minix x7
    nfs.ko module failed to install
    Hi Wasser,
    Good to see you back online!
    I have an issue ATM getting the nfs.ko module to install. Any ideas as to why?
      Originally posted by xatang2013 View Post
      Hi Wasser,
      could you please try following steps in terminal and post the /sdcard/dmesg.log /sdcard/lsmod.log ?
      su -
      busybox insmod /system/lib/modules/sunrpc.ko
      busybox insmod /system/lib/modules/auth_rpcgss.ko
      busybox insmod /system/lib/modules/lockd.ko
      busybox insmod /system/lib/modules/nfs.ko
      dmesg > /sdcard/dmesg.log
      lsmod > /sdcard/lsmod.log
      thanks
        su -
        thanks
        Thanks Wasser. I will try tonight and post my result.
          su -
          thanks
          Hi Wasser,
          Here are the log files:
          dmesg.txt lsmod.txt
          BTW, I got another NFS modules package from lewy20041 and was able to installed all the modules through Terminal successfully. I noticed his nfs.ko module file size is a little bigger than the one you included. However, I am facing the same issue with my T-R42 box where NFS mount commands failed with message Device or Resource is busy. Both my Minix X7 and T-R42 devices failed to mount NFS shares with Device or Resource is busy message.
          I'm scratching my head as to why. Both my boxes currently have no problems mounting CIFS through script and NFS through XBMC.
