Does anyone else happens this with the settings?
Arnova 7G2 Finless 1.5 Beta Test ROM
Originally posted by Miklaus View PostI'm sorry but anybody had said anything about this issue
TURBO
Same here
Originally posted by TURBO View PostHi Bob. Just discovered the new ROM. Thanks to all contributors. Everything installed fine.The brightness setting just closes. That's the only issue, so far. I will report more as soon as I find it. I love this new rom. Fast, super fast.. Thank you.
TURBO
Gary
TURBO
Originally posted by vrailink View PostWhen I look at my memory usage it says I have a total of only 287mb. Doesn't the Arnova 7 G2 has 512mb ram. Or is there a portion used for something else?. This happens with all android devices.
feedback
[QUOTE=Finless;8779]UPDATE April 19 2012.
The first Beta had issues with the new clear systemUI and the new settings.apk. ROM is nou updated without the clear system UI but a new settings menu. I tested settings using my 10 G2 kernel and it works.
ROM is now BETA rev b.
The link below is updated and the new file name is:
arnova7g2_finless _v1_5b_beta.zip
Let us know how it works.
hi bob,
just installed your rom.. appinjector works very smooth
clear statusbar not working
settings ( brightness ) force closed..
market works really great no need to go on any hassle clearing cache...
wifi works fine....
thanks nice rom... ill report again if i found a bug
__________________________________________________ _Last edited by mhajho; 24 June 2012, 22:43.Sent via GT-i9003
firmware: CyanogenMOD 4.0.4
Originally posted by mhajho View PostLet us know how it works.
hi bob,
wifi works fine....
is there a posibility that we can change the icon on the status bar?
https://play.google.com/store/apps/d...ZXNzbGV2ZWwiXQ..
re
to change status bar icon... just pull out systemUI.apk..... using root explorer or any other app... located at system/app.... then extract it using winrar or any other... change the icon manually but make sure its the same size.. or else it will have problem on displaying correctly.... its located at res/drawable hdpi... change the icon and rename it as is..... hope guys will like thisSent via GT-i9003
Originally posted by mhajho View Postto change status bar icon... just pull out systemUI.apk..... using root explorer or any other app... located at system/app.... then extract it using winrar or any other... change the icon manually but make sure its the same size.. or else it will have problem on displaying correctly.... its located at res/drawable hdpi... change the icon and rename it as is..... hope guys will like thiscan you upload yours?
Them icons look cool
Sent from Xperia Mini Pro ~ Android 4.0.4 ICSPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by vrailink View Postnicely done.can you upload yours?
Originally posted by Damo View PostThem icons look cool
Sent from Xperia Mini Pro ~ Android 4.0.4 ICSSent via GT-i9003
There are currently 2601 users online. 0 members and 2601 guests.
