Do we need only SD or do they support SDHC and SDXC formats ? What class do they support - 2,4,8,10 ?
SD Card format for Android Sticks
STICK
Originally posted by namarayaj View PostWhat format of SD card does these Android sticks support ?
Do we need only SD or do they support SDHC and SDXC formats ? What class do they support - 2,4,8,10 ?I do know they use sdhc as my K-R42 and my OUYA uses sdhc
What is the world if you don't explore?
NTFS is supports by "most" 4.1.1 and up ROMs. But not all!
The default is FAT32. If NTFS does not work on your device use FAT32.
Originally posted by Finless View PostNTFS is supports by "most" 4.1.1 and up ROMs. But not all!
But would like to know, What is the best, secure and faster format to use with 32MB and 64MB SD and XC Cards on these Android TV sticks?
You mentioned that is better to use FAT32 or NTFS for 16 or 32MB SD-Cards?
But, what about EXT-FAT formats for SDXC 64MB cards?
Is Possible to partition these 64MB SDXC Cards?
Perhaps.. you mean GB
I have one unit.. thats using 'ext 2' on the sdcard..
It all depens what firmware you are running.. there is a tread where a x7 has a 64gb exfat sdcard
Choose your firmware.. then see.. what works..and what does not..
Cheers
Originally posted by mitchell4you View PostI thought.. the did not make these any more (32 and 64 mb cards )
Cheers
Yes I mean 32GB and 64GB...
Do you know the link of the tread where a x7 has a 64gb exfat sdcard?
I have a CX-919 with Neomode 1.7 ROM, and various 32GB SD + 64GB SDXC Cards, but since FAT32 don't allow to read/write over 4/5GB archives, I would like to use a faster and newer file format, that can handle these larger files.
There are currently 2122 users online. 1 members and 2121 guests.
