I've got a Pipo M9 which I recently flashed a new firmware to.
Accidently I flashed a Pipo M9 PRO fw on it, and realised my mistake after a while.
So I went over the process again and flashed the regular M9 fw on it.
It booted up okay, so far so good.
But now my touchscreen isn't working at all. It's like the cable to the screen isnt connected.
I cracked the tablet open and checked the cable, and it's in place, so that's not the case.
I've tried many different roms and versions to get it working, but with no luck.
The OTG port works ok though, so I can navigate the tablet with a mouse.
Is there any way to fix this, or is my touch screen dead?
Regards
