Here are some customised kernels for the X7. Each is built from sources using Marvin.
Generic features:
- Device: Neo X7
- Resolution: 1080p
- vsfsam video fix
- Backported ondemand governor from Linux kernel 3.12 (http://www.freaktab.com/showthread.p...l=1#post108134)
- Default governor: ondemand
- Default i/o scheduler: noop
One of the kernels (cpu1800h_ddr667_gpu600h_vsfsam) is not really overclocked. Each hw component is actually "de-underclocked" to its rated limit. In addition the CPU scaling with this kernel starts from 1008MHz (1200MHz with the others, except the one which utilises the full scale from 312MHz to 1800MHz).
Big thanks to Phjanderson for Marvin and making the kernel sources for X7 available, to Sam321 for the video fix and to Stratos Karafotis and JungsteR for the ondemand governor fix.
Best Regards,
Markus
