How to change Splash Screen (NOT BOOTANIMATION) in 900Supersport ROM U30GTH ??
900Supersport
freaktab developer
I'm going crazy, Brian !!
Is it so difficult to put a BLACK SCREEN up to bootanimation ? I don't want "double peas" or other images till bootanimation. SIMPLE !
- I tried linux with your kitchen but at the kernel menĂ¹ there isn't "b" (even if I press "?" button)
- RKCRC doen't work in linux
- RKCRC in windows creates a fake kernel.img
I don't know what else to do.
Could I get a step by step guide ??
Thanks guys !!
Thanks guys !!900Supersport
freaktab developer
I'd be happy to take a look at doing this for you. I'd need a PNG of the image you want and a copy of the kernel. if you can upload them and pm me the link I'll take a look tomorrow evening.900Supersport
freaktab developer
Originally posted by 900supersport View PostI think this may run stand alone on windows
I have a working python script, by no means the finished product but it does a job. Use a follows
in a folder working ensure you have kernel.img, logo_clut and logo_data.
from the folder containing working (on up) execute the python script.
sign kernelout.img
Code:rkcrc -k working/kernelout.img kernel.img
Code:#!/usr/bin/python #globals cluto = 0 # clut offset pl = 0 # palette length datao = 0 # data offset w = 0 # kernel data image width h = 0 # kernel data image height ds = 0 # kernel data image size def findstring(f, s): '''find the first occurance of the string s in the file f ''' l = len(s) o = 0 f.seek(o) while f.read(l) != s: o = o + 1 f.seek(o) return o + l def printkerneldata(): '''get kernel data ''' global cluto # clut offset global pl # palette length global datao # data offset global w # kernel data image width global h # kernel data image height global ds # kernel data image size with open('working/kernel.img', 'r') as fr: o = findstring(fr,'ppllogo_RKlogo_clut') fr.seek(o) cluto = o pl = int(fr.read(1).encode('hex'),16) print '==================================================' print 'ppllogo_RKlogo_clut offset:', print "{0:x}".format(cluto) print 'Palette length:', pl print '==================================================' o = findstring(fr,'logo_RKlogo_data') fr.seek(o) datao = o w=int(fr.read(2).encode('hex'),16) h=int( fr.read(2).encode('hex'),16) ds = w * h + 4 print 'logo_RKlogo_data offset:', print "{0:x}".format(datao) print 'resolution: ', print w,':',h print 'data size: ', print ds print '==================================================' def brandkernel(): global cluto # clut offset global pl # palette length global datao # data offset global w # kernel data image width global h # kernel data image height global ds # kernel data image size with open('working/kernel.img', 'r') as fr: #fr.seek(8) with open('working/kerneltmp.img', 'w') as fw: fw.write(fr.read(cluto)) with open('working/logo_clut') as ft: for c in iter(lambda: ft.read(1),""): fw.write(c) fr.read(1) for c in iter(lambda: fr.read(1),""): fw.write(c) #print datao with open('working/kerneltmp.img', 'r') as fr: fr.seek(8) with open('working/kernelout.img', 'w') as fw: fw.write(fr.read(datao-8)) with open('working/logo_data') as ft: for c in iter(lambda: ft.read(1),""): fw.write(c) fr.read(1) for c in iter(lambda: fr.read(1),""): fw.write(c) printkerneldata() brandkernel()
This was the test code I developed prior to integrating into my kitchen.
900supersport, lewy20041 very nice work.
I found a mistake in, for windows should be:
Code:rkcrc -k kernel.img working/kernelout.img
1. From 900supersport link
2. From lewy20041 link
3. Your kernel.img file
4. Your new logo.png file (must be png file, rename to logo.png if nessesary)
5. From myself: logo-change-script.zip
Script itself:
Code:@echo off call png2clut224.bat logo.png rkcrc -k kernel.img working/kernelout.img echo. & echo. echo All done. pause > nul
Error code
In my case
I do in ubuntu and while trying to write the logo_clut and logo_data got this exception
Traceback (most recent call last):
File "./FreakTabKitchen.py", line 104, in <module>
StartKitchen()
File "./FreakTabKitchen.py", line 93, in StartKitchen
logerror('FreakTabKitchen::StartKitchen ',e,1)
File "/home/jokobuntu/POP/rkKitchen-master/utils.py", line 245, in logerror
raise myerror
ValueError: invalid literal for int() with base 16: '8L'
I almost there I believe
Please help
where is the file?
@900supersport
where is this tool? i want to download it , it says " Sorry, the file you have requested does not exist."Last edited by tiku; 03 November 2014, 13:49.
I think that was a tool posted by another user. I'll see if I still have a copy of it.900Supersport
freaktab developer
There are currently 4955 users online. 1 members and 4954 guests.
