How to add superrepo on 13 alpha 7?
Originally posted by mitchell4you View PostDownload zip file..
Xbmc --> system --> settings -->addon --> install from zip
Browse to zip.. click on it
Wait for it (right corner -popup ) then its installed
Next.. Home -xbmc
Video - addons - get more..
Install anything you like.. (v13a7 sometimes crashes on install.. known issue)
Cheers..
imposible;p
to make sure its zip just unpack archive you have and use winzip to zip it up again.Everything is possible if we work together!
Anyways i managed to install addons using Fusion.
Has anybody managed to stream 720p movies from icefilms? I try to play 720p movies but it just streams the first 2-4 seconds and then it stops
ice films
Originally posted by convict View PostI installed OUYA XBMC but it stills doesn't see zip files and i'm unable to browse into my internal nand flash.
There are currently 2614 users online. 1 members and 2613 guests.
